Preference of Angular frequency over frequency for sinusoidal graphs
The discussion centers on the preference for angular frequency (ω) over frequency (ν) when analyzing sinusoidal graphs. The primary reason for this preference is that using ω simplifies calculations by eliminating the need for repeated factors of 2π, as trigonometric functions are more straightforward in radians. The relationship between displacement, velocity, and acceleration becomes clearer without the 2π factor when using ω. Examples provided illustrate that equations for oscillation frequency, such as for a mass on a spring or a simple pendulum, utilize ω without introducing 2π. This approach enhances clarity and efficiency in mathematical expressions related to oscillatory motion.
sbstratos79
Quote from 'The Physics of Vibrations and Waves by H.J.Pain': "However when we solve the equation of motion we shall find that the behaviour of x with time has a sinusoidal or cosinusoidal dependence, and it will prove more appropriate to consider not \nu, but the angular frequency \omega = 2\pi\nu so that the..."
My question is, why are we prefering \omega over \nu just because of the fact that the graph will be sinusoidal/cosinusoidal? Does it make the calculations somehow easy, or has it got some other purpose?
The math works out MUCH easier if the trig functions are measured in radians. Otherwise, there are far too many factors of ##2\pi## to keep track of.
so, according to you, we prefer \nu over \omega. O.o but the book says that we prefer \omega over \nu. \omega contains 2\pi
The way I interpret your notation, ##\nu## means the number of complete cycles of the oscillation per unit time, and ##\omega## means the number of radians per unit time.
The book has used ##2\pi## once in its definition or explanation of what ##\omega## is. You won't find ##2\pi## again when you use ##\omega##.
For example if the displacement of something is ##A \cos \omega t##, its velocity is ##-A\omega \sin \omega t## and its acceleration is ##-A\omega^2 \cos \omega t##. No factors of ##2\pi##.
If you have a mass m on a spring of stiffness, the oscillation frequency is ##\omega = \sqrt{k/m}##. For a simple pendulum, ##\omega = \sqrt{g/l}##. Again, no factors of ##2\pi##.
Likes 1 person
ah, i see... Thanks a lot for the help, sir ^_^
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
