Can Charge and EM Energy Change Metal Structure
The discussion centers on the concept of "break-in" for audio cables, where users report improved sound quality after extended use. However, many participants argue that these claims lack scientific validation, with no peer-reviewed studies confirming changes in cable structure or sound quality due to break-in. The consensus suggests that any perceived improvement is likely psychological rather than physical, as the materials do not undergo detectable changes during normal use. The flow of energy through metals can cause heating, but this does not affect the cable's sound performance as claimed. Overall, the topic highlights skepticism towards audiophile claims about cable performance and emphasizes the need for empirical evidence.
bachrocks
Hello Everyone,
This is my first post.
Background: I am an audio guy and seek to understand how cables contribute to the sound of my stereo.
Issue: Do audio cables such as power cords, interconnects, and speaker cables "break in" as they are used? Typically, with high-end cables, users experience a break-in period where the sound is not optimal. Then, after a certain amount of hours--let's say 100-200, for example--the sound improves. In any case, this is a debatable topic, but for the purpose of this post, let's assume that they do break-in.
Question: I would like to ask if the flow of charge and energy through wire such as cooper or silver can change the structure of the metal in any way?
Closing: I do have a chemistry background, but I am quite weak with EE matters. Actually, my EE friend attributes the break-in to the insulator, not the wire. I believe him, but as I naively thought the metal might somehow change, I would like to ask the above question.
thank you,
ron
hi Ron
welcome to PF
seriously, it sounds like you have been getting too swayed by the audiophile fringe element :wink:
there's a whole bunch of characters out there with some incredibly wild and unfounded claims to cables and connectors etc.
as far as I'm aware pretty much none of the claims have withstood the scrutiny of lab tests under controlled conditions.
Their claims are all very personally subjective
Dave
Welcome to PF;
Electrical components do change with time, but mostly to make them worse rather than better. It's just entropy at work.
The reported break-in effect is psychological.
http://www.audioholics.com/audio-video-cables/audio-cable-break-in-science-or-psychological
... seems to have a fair discussion. Includes the "insulator" argument.
Not sure about the conspiracy theory argument - but certainly some salesfolks like to repeat the myth.
Anyone wants to confirm the "myth" will need to provide peer-reviewed references in support.
At least a reference to randomized double-blind tests, from a reliable source.
AFAIK: no such tests have confirmed the myth.
You can do the test yourself - find someone who reports a break-in period and see if they can tell between new and used cables. First make sure they can tell when they know it's the new one.
The flow of energy through a metal can change it, depending on the amount of flow. i.e. it can warm up. Some material properties depend on temperature etc. But that's not what you are talking about. The short answer is "no" - over the reported break-in period, there are no detectable changes in the metal of the wire during normal use, and the insulating dielectric does not become attuned, oriented, or polarized, to the wire.
The biggest influence on the sound quality from new wires is the psychology of the listener.
Beauty is in the eye of the beholder.
Thank you so much Dave and Simon for your really fast reply. I deeply appreciate you help. :thumbs:
Cheers from Bangkok, Thailand,
ron
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
