Varible Frequency Microwave Oven
A user seeks a microwave oven capable of using a specific wavelength to selectively heat parts of a composite sample, highlighting that conventional microwaves operate at a fixed frequency of 2.45 GHz. The discussion reveals that typical microwave ovens do not allow for adjustable frequencies or amplitudes, which complicates the user's needs. There is a suggestion to explore materials based on their microwave absorption spectra to achieve the desired heating effect. Concerns about safety arise if the user must build a custom solution due to the lack of existing products. The conversation emphasizes the need for precise control in microwave heating applications.
duordi134
I have a need for a microwave oven which uses a specific wave length to heat a specific part of a composite sample more than another part of the sample.
Normal microwave ovens have a random frequency and amplitude and the frequency is not adjustable.
A radio like a short wave radio would work but it does not have an adjustable carrier wave.
I would have to have an adjustable carrier wave.
The frequency and the amplitude could remain constant while the signal was intermittent or the amplitude could be varied while the signal remained constant.
My hope is that something like this is exists already which can be purchased.
If not I will have to build one which brings up some safety concerns.
Any thoughts?
Thanks
Duordi
Normal microwave ovens have a random frequency ...
i don't think that is so.
I think they operate at 2.45ghz.
agreed ... their freq is well defined and any freq drift is likely to be reasonably low
from what I have read, in days gone bye, around a couple of MHz
cheers
Dave
You can still expect an initial chirp of about 100MHz while a magnetron approaches operating temperature.
Do you want to select which material is heated based on microwave absorption spectrum?
If so what materials are you trying to differentiate and what are their absorption spectra.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
