The inverse of a banded matrix
  • Thread starter Thread starter EngWiPy
    Inverse Matrix
Inverting a banded matrix directly can lead to increased complexity, as the resulting inverse will be fully populated rather than maintaining the banded structure. Instead of inverting the matrix, it is more efficient to solve a set of equations or use matrix decomposition methods like LDU, where L and U are lower and upper triangular matrices that retain the bandwidth. This approach avoids unnecessary computations involving zero terms in the decomposed matrices. The discussion emphasizes that matrix inversion is generally not advisable in computational contexts. Understanding these methods can significantly enhance efficiency in handling large matrices.
EngWiPy
Hello all,
I have say 512-by-512 matrix, but based on the structure of this matrix most elements not on the diagonals between -5 to +5 (- stand for diagonal below the main diagonal, and + for diagonal above the main diagonal) are small relative to the elements of the mentioned diagonals. So, I create a 512-by-512 banded matrix, where I null all other elements not on the mentioned diagonals.
Now the question is: will there be a huge complexity saving if I want the inverse of the matrix by inverting its banded version instead of the original matrix?
Thanks
Mathematics news on Phys.org
In computer calculations, "inverting a matrix" is almost always the wrong thing to do, even if you have a nice looking math equation with an inverse matrix in it.
In this case there will be a huge "complexity" increase, because the inverse matrix will be fully populated, not banded.
What you really want to do is probably solve a set of equations or something similar. If you decompose your banded matrix as A = LDU or something similar, where L and U are lower and upper triangular and have the same bandwidth as A, you preserve the efficiency by not needing to process all the zero terms in L and U.
Could you please tell me more about this process?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
