How can I use math to calculate the distance of a trebuchet-launched projectile?
To calculate the distance of a projectile launched by a trebuchet, one can apply principles of physics, specifically projectile motion equations. Resources shared in the discussion include links to detailed analyses and algorithms that can assist in understanding the calculations involved. The discussion suggests that the topic may be better suited for a general physics forum due to its complexity. Additionally, a simple Java algorithm was mentioned as a practical tool for building trebuchet models. Understanding the underlying math and physics is essential for accurate distance calculations.
whatzzupboy
I was just woundering how to find the distance of a projectile, when thrown by a trebuchet, mathematicly?
This should probably be moved to the general physics section, as its not really a homework problem. That said, the explanation is long and unwieldy, though I did find a few links for you
http://www.geocities.com/SiliconValley/Park/6461/
http://www.ripcord.ws/FATAnalysis.PDF <--- not sure how much math you have under your belt, but I found this one the most interesting of the lot
http://home.att.net/~wjahsman-mta/RetroMechanics.pdf
Here's a simple Java algorhythm that I used when building mine. There is a downloable versio that a bit more user friendly that I like.
http://www.algobeautytreb.com/javatreb.html
