What Formula to Use for Elevator's Constant Acceleration Problem?
To solve the elevator's constant acceleration problem, use kinematic equations to determine the distance and time for each phase of the elevator's motion. For part (a), calculate the distance the elevator travels while accelerating to its maximum speed using the formula x = 1/2at². For part (b), break the journey into three phases: acceleration to top speed, constant speed travel, and deceleration back to rest. Calculate the time and distance for each phase, ensuring consistent units throughout the calculations. This structured approach will yield the correct answers for the total distance and time of the elevator's run.
mb85
hello. i am confused on what forumla in particular you use to figure the answer out?
A certain elevator cab has a total run of 209 m and a maximum speed is 322 m/min, and it accelerates from rest and then back to rest at 1.16 m/s2. (a) How far does the cab move while accelerating to full speed from rest? (b) How long does it take to make the nonstop 209 m run, starting and ending at rest?
Assuming the acceleration is constant, you can use a=∆v/∆t, and then x=1/2at2. For the second part, you'll need to separate into three phases: acceleration, constant velocity, and decceleration. Find the time each part takes. Also, remember to use the consistent units.
im still confused.. and am not getting the correct answer on egrade. :(
there's three separate parts:
1. the car is accelerating to its top speed
2. the car is moving at its top speed
3. the car is decelerating to rest
for part A, you just need to use kinematics. you are given enough information to use the equations and get the answer.
for part B, you need to use the three parts. find the distance that the car travels at the max velocity, and get the time. you can add this time to the time it takes to accelerate and decelerate.
