Crystalline diffraction problem
  • Thread starter Thread starter furtivefelon
    Diffraction
The discussion centers on a problem involving the use of x-rays to study the crystalline structure of NaCl through diffraction. Bragg's law is highlighted as the key equation for relating interplanar spacing and wavelength, specifically 2dsin(θ) = mλ, where θ is the glancing angle and m is the order of diffraction. To find the wavelength of the x-rays, one must apply this equation using the given parameters. Additionally, it is explained that visible light cannot be used for diffraction studies on crystals due to its longer wavelength, which is ineffective for resolving the atomic scale of crystalline structures. Understanding these principles is crucial for solving the problem effectively.
furtivefelon
There is one problem in the problem set i don't know how to approach it..
Problem:
While an artificial diffraction grating is used to study a spectrum of a light beam, electromagnetic waves with wavelengths much less than the wavelength of the visible light are used to study the natural diffraction
grid, namely a crystalline structure. Electromagnetic waves in this range are called the x-rays. The condition for constructive interference is given by Bragg’s law:
2dsin- = m+, m = 1, 2, 3, …
If the wavelength and diffraction angle are measured, the Bragg equation can be used to calculate the spacing between atomic planes.
In our problem, the crystalline of NaCl with density D = 2.16 g/cm3 is exposed to x-rays with the glancing angle - = 60.0o. The reflected rays form the second order maximum.
(a) Find the wavelength of x-rays used in the experiment.
(b) Explain why the visible light cannot be used to obtain the diffraction pattern on crystals.
i don't understand what equation relates the interplanar spacing and density together, or am i on the wrong track?
Thanks alot!
The equation relating the interplanar spacing and density together is Bragg's law. It states that the wavelength of the x-rays used in the experiment can be calculated by 2dsin- = m+, where m is the order of the diffraction pattern, d is the interplanar spacing, and is the glancing angle. In order to answer (a), you will need to calculate the wavelength of x-rays using the equation above. In order to answer (b), you can explain that visible light has a much longer wavelength than x-rays, making it less effective at diffracting off of crystalline structures and thus not suitable for obtaining a diffraction pattern.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
