How Much Water Can Lightning Boil Away from a Tree?
  • Thread starter Thread starter mpm
    Physics
The discussion focuses on two physics problems related to lightning and electric fields. The first question involves calculating the amount of water that can be boiled away from a tree after a lightning strike, using the energy transferred by the lightning based on the charge and potential difference. The second question pertains to determining the electric field strength at a specific distance from a uniformly charged insulating sphere, applying concepts of electric fields and charge density. Key formulas include energy transfer calculations and the relationship between electric fields at different distances. Understanding these principles is crucial for solving the problems effectively.
mpm
I need help with 2 questions that I can't seem to figure out. I had them for homework but I never got it right and the homework has since been turned in.
I was told I would most likely see these problems again on the exam. Therefore I need to learn how to do them. Can anyone help me out on these?
Question 1:
A certain strom cloud has a potential difference of 8.9 x 10^7 V relative to a tree. Water has a specific heat of 4186 J/kg*C, a boiling point of 100 Celsius and a heat of vaporization of 2.26 x 10^6 J/kg.
If, during a lightning storm, 52 C charge is transferred through this potential difference and 1.96% of the netery is absorbed by the tree, how much water (sap in the tree) initially at 20.9 Celcius can be boiled away? Answer in kg.
Question 2:
An insulating sphere of radius 14 cm has a uniform charge dnesity through its volume. If the magnitude of the electric field at a distance of 7.5029 cm from the center is 98545.6 N/C, what is the magnitude of the electric field at 28.0078 cm from the center? Answer in N/C. (Radius of sphere is 14 cm)
If anyone can help me I would really appreciate it.
1) this problem is very simplified.. you know that E=QV where E is the energy transfered, Q is the charge transferred and V is the voltage difference in which it was tranfered with.
now just calculate how much energy you transferred to that tree and how many kilo's of water you can vaporize with it...
as for the second question:
the field of a uniformly charged sphere is like a point charge at the middle with the net charge...
E=\frac{Q}{r^2}
you can find the net charge, and calculate the field at the new distance, or just say the ratio between the fields is equal to the square of the ratio between the two radii.. \frac{E_1}{E_2}=(\frac{r_2}{r_1})^2
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
