Visible Light Reflection from Oil-Water Interface in Parking Lot
A thin layer of oil (n = 1.25) on water (n = 1.33) in a parking lot can reflect specific colors of visible light based on its thickness of 242 nm. The formula 2t = m*lambda/n is used to calculate the wavelengths that will experience constructive interference. The extra path length for reflection occurs within the oil layer, not through the water. To find visible wavelengths, start with m = 1 and calculate lambda for each integer value until reaching the visible light spectrum (400 nm to 700 nm). This approach will reveal which colors are strongly reflected due to the oil's thickness.
truckerron1
A tiny layer of oil (n = 1.25) is situated on top of a water puddle (n = 1.33) in a parking lot. If the thickness of the oil is 242 nm, the what color(s) of visible light will give a strong reflection?
2t=m*lambda/n2
2t=242nm/1.25 and then 2t=242nm/1.33
i just don't know what goes where on this problem please help thanks ron
242 nm is the thickness of the oil (t), not the wavelength of the light (lambda).
so how do i set it up if t=242
so would it be
2(242)=m*1.25/1.33
No, NONE of the light that gets reflected travels through the water.
The extra path length (which is responsible for the constructive interference)
travels down thru the OIL and back up thru the OIL.
You should expect the OIL thickness to be associated with the OIL index.
You're trying to SOLVE for lambda ...
In addition to lightgrav's useful comment, I'll add that at this point you may be wondering what to use for m?
Each integer value of m (1, 2, 3, ...) gives a possible wavelength, in principle. However, you specifically need only the wavelengths that are visible, that is, in the range 400nm to 700nm. So start with m = 1 and calculate lambda for each value of m in turn. It will be pretty obvious when you can safely stop (i.e. after you've gone through the entire visible range).
