#2 Variation of parameters with complemetry EQ (Diffy Q)
Weatherkid11
Given that http://forums.cramster.com/Answer-Board/Image/cramster-equation-200641003458632802260985487500893.gif is the complementary function for the differential equation http://forums.cramster.com/Answer-Board/Image/cramster-equation-200641003635632802261951581250765.gif use the variation of parameters method to find a particular solution of yp
Well i think i use the wronskian 1st, so that would be w= http://forums.cramster.com/Answer-Board/Image/cramster-equation-2006410038406328022632042375002059.gif then i use the integrals to find u1 and u2. But what do I do next?
Anothere one? You seem to have imperfectly memorized formulas rather than actually learning what to do. Where did you get the formulas to memorize? Don't you have a textbook? This is a good example of why it is better to LEARN concepts than to memorize formulas.
Since you know that x2 and x3 satisfy the homogeneous equation, you look for solutions to the entire equation of the form y(x)= u(x)x2+ v(x)x3. Then y'= u'x2+ 2ux+ v'x3+ 3vx2. Now, require that
u'x2+ v'x3= 0. That leaves y'= 2ux+ 3vx2 and y"= 2u'x+ 2u+ 3v'x2+ 6vx. Putting that into the differential equation, x2y"- 4xy'+ 6y= x2(2u'x+ 2u+ 3v'x2+ 6vx)- 4x(2ux+ 3vx2)+ 6(ux2+ vx3= 2x3u'+ (2- 8+ 6)x2u+ 3x4v'+ (6- 12+ 6)x3u= 2x3u'+ 3x4v'= x3. For x not 0 (which is a singular point anyway) 2u'+ 3xv'= 1. Because we required that u'x2+ v'x3= 0, there is no u" or v" and because x2 and x3 satisfy the homogeneous equation, all terms involving u and v without derivative cancel so we have only an equation in u' and v'.
We also have the requirement u'x2+ v'x3= 0 or, (again for x not 0), u'+ xv'= 0.
Solve the two equations u'+ xv'= 0 and 2u'+ 3xv'= 1 algebraically for u' and v' and then integrate.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
