Calculating Kinetic Energy & Speed of a Particle in Beta Decay Reaction
To calculate the kinetic energy of a particle released in a beta decay reaction, subtract the mass of the daughter nucleus from the parent nucleus to find the mass difference. This mass difference is then multiplied by 931.5 MeV/u to obtain the energy, which represents the kinetic energy of the emitted particle. The relationship E=1/2mv^2 can be rearranged to find the speed of the particle once the kinetic energy is determined. The discussion clarifies that "u" refers to atomic mass units, specifically 1/12 of the mass of a carbon-12 atom. Understanding these concepts is essential for accurately calculating the properties of particles in nuclear reactions.
roy5995
How do i calulate the kinetic energy and speed of a particle released form a beta decay reaction?
for example, if i have Na -> Mg + e (i can't type in the atomic masses and numbers)
Would i subtract the mass of Mg from Na ?
m=m_Na-m_Mg
=23.990961u-23.985042
=0.005937u
then multiply that mass by 931.5 (b/c 1u=931.4MeV)
E=0.005937*931.4
=5.5297MeV
^^^is that the kinetic energy, or is that the energy released? they are different right?
does finding the kinetic energy involve something with the masses of daughters and masses of parents?
Once i have found the correct energy would i just rearrange the equation E=1/2mv^2 to find the speed?
Also, is the mass of, for exapmle, oxygen is 15.003065u, what is that is kg?
what does u mean? and what is the mass of an electron in 'u'
You have caluculated the difference between the mass of Na and the mass of Mg but you still have the mass of the electron. If you add the mass of Mg to the mass of the electron what do you get? Is that the same as the mass of Na? If it is less, where do you think the extra mass went? (Hint: E= mc2!)
As far as "oxygen is 15.003065u" is concerned I have no idea what "u" is. My first thought was that is was really μ ("mu" for "micro-") but even that requires a base such as gram.
Are you really saying that none of this is in your textbook?
I believe u here is atomic mass unit which is defined as mass of one C-12 atom
You mean 1/12 of the mass of one C-12 atom, right?
