pavadrin
- 154
Hey
I am given the set volume for a cylindrical container and separating pricing for the material used to construct the container, the base and the side wall. The ends of the container cost $0.05 per cm2 and the side walls $0.04 cm2, and the volume is 400 mL. The question asks: What is the best design for the container i.e., measurements to ensure that cost is at a minimum.
_________________________________
my working:
V = 400 mL
Ends costs $0.05 per cm2
Side wall costs $0.04 cm2
Area of ends = 2 \pi r^2
Area of side wall 2 \pi r h
V = 400, therefore since V = \pi r^2 h, h = \frac{400}{\pi r^2} (1)
Cost for one container = 0.05 (2 \pi r^2) + 0.04 (2 \pi r h) (2)
Therefore substituting (1) into (2), cost = 0.05 (2 \pi r^2) + 0.04 (2 \pi r \frac{400}{\pi r^2})
Differentiating the cost function gives: \frac {dC}{dr} = 0.2 \pi r + \frac {96}{r^2}
The value of r where there is no rate of change = -5.34601847
I am not sure if what I have done after and including the differentiation is correct. Since I have got a negative answer for the value of r, I am thinking that what I have done is wrong, as you cannot have a negative radius. Would the second derivative help with the sloving this equation, if so how?
Many thanks,
Pavadrin
my working:
V = 400 mL
Many thanks,
Pavadrin
