Computer Amplifier: Designing a Multiple Stereo Output System
The discussion focuses on designing a multiple output stereo amplifier for a computer, incorporating both quarter-inch and eighth-inch inputs, and aiming for four stereo outputs of 20-60 Watts each. The proposed design utilizes op-amps in a non-inverting configuration, with a total of eight amplifiers to manage multiple speaker outputs simultaneously. Concerns are raised about using two eighth-inch headphone jacks in parallel and the implications of low resistance, as well as the compatibility of headphones with speaker amplifiers. Participants suggest considering a push-pull circuit design for better performance and emphasize the importance of understanding the output specifications of the sound card being used. Overall, the design aims to achieve flexibility in speaker and headphone use while addressing potential technical challenges.
D_Dean
Hello,
I have a few questions about creating a multiple output stereo computer speaker amplifier. I am using a standard audio output from the computer. Basically what I want is to have:
1. Both quarter inch and eighth inch stereo jack input, but only one at a time will be used. I figure if I put them in parallel that would solve that problem.
2. I want 4 stereo 20 - 60 Watt outputs. I would like to use any combination of the speakers at a time (say all four pairs, just one, etc at the same time). I am thinking about using opamp with a feedback loop. This is the one I am currently considering:
http://www.national.com/ds/LM/LM675.pdf
I would use the "Non-Inverting Amplifier" design from the datasheet (The first schematic). The plan would be to have a total of 8 amplifiers (left and right for 4 speaker outputs). My understanding is that the input current to each amplifier is low enough such that it is ok to have all 4 pairs to run at the same time, can I make this assumption?
3. I also want to have 2 eighth inch jack stereo headphone outputs. I figure I can just hook those up directly to the inputs. Will it be a problem to use two in parallel at the same time (ie: can one use two headphones in parallel off of one standard audio card)? How might I solve the problem of the low resistence of the two parallel headphones? Also, my understanding is that the input resistance to each opamp is high enough to where it will not be a problem to have say a headphone in parallel with a speaker amplifier, am I correct to assume that?
I guess my question is what do you think about this design idea. Is there a significantly better way to solve my design needs? Are there any other problems that you forsee in this design?
Thanks in advanced,
D Dean
I can't remember off the top of my head, but I think you'll want a push-pull circuit. I loaned out my electronics book so I can't look anything up.
Most of the designs that I've looked at are built with a bipolar network: most being a common-emitter (or differential pair) feeding a push-pull output stage. I figured that since I plan to have 8 separate amplifications it would be a lot easier if I could just use a chip like the one in my first message. Looking at the schematic for the opamp it is basically that (with more voltage amplification stages and filtration).
Does anyone know the standard for the output voltage and maximum current for a PCI sound card. I realize the max current may fluctuate with different devices. I have the Sound Blaster 5.1 PCI Card from soundblaster.com. They aren't too detailed about the device specifications.
Thanks
The designations Line In/Line Out have a general standard.
You can look this up. Your card should be close to that.
For a power output, if they don't tell you, then you can determine it with test equipment.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
