How is Angular Momentum Conserved in Electromagnetic Fields?
golfingboy07
Question1: Discuss the conservation of angular momentum for a macroscopic system of sources and Electromagnetic fields in a uniform isotropic dispersionless medium of permittivity epsilon and permeability mu.
Question2: Show that the differential form of the conservation law is:
∂/∂t(Lfield + Lmech) + div(M) = 0
where L-field = μεx x (Ex H)
and M = T x x
T is the Maxwells stress tensor
I am wanting help with both these questions
1st question: Would like some help to get started such as a couple of bullet points
2nd question: Not sure where to start
Thanks
GM
The derivation for linear momentum is in most textbooks. Just repeat it for rXP. I suggest you look at "Classical Electromagnetism" by Franklin, which shows when to use E,D,B,H.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
