Does a Spring Stretch More When Attached to an Immovable Wall or When Detached?
  • Thread starter Thread starter hatingphysics
    Conceptual Spring
When a spring is attached to an immovable wall, two people pulling on it generate a total force of 2F, leading to greater stretch. In contrast, when the spring is detached, each person still pulls with a force of F, but the total force remains 2F as well. The difference lies in the spring's ability to resist deformation; when attached, it can stretch more effectively due to the wall's resistance. The discussion raises questions about the mechanics of force distribution and the spring's response in both scenarios. Ultimately, the spring stretches more when attached to the immovable wall due to the consistent force application and resistance.
hatingphysics
Two people pull on a horizontal spring that is attached to an immovable wall. Then, they detach it from the wall and pull on opposite ends of the horizontal spring. They pull just as hard in each case. In which situation, if either, does the spring stretch more?
I think that the spring would stretch more when it is attached to the immovable wall because it is immovable and the force being put on the spring is more than the 1 people. I may be wrong though!
But you may be right. Okay, in the first case, you do have 2 people pulling, each with a force F. That's a 2F total force on the spring. What about in case 2? They each pull with a force F. You must explain why you think there would be less stretch in this case. What is the total force applied to the spring in this 2nd case?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
