Finding the Third Force to Achieve Zero Total Torque on an Equilateral Triangle
  • Thread starter Thread starter merced
    Torque Triangle
To achieve zero total torque on an equilateral triangle with forces F_1 and F_2 acting along two sides, a third force F_3 must be applied at point B along side BC. The sum of the torques around point O must equal zero, necessitating the calculation of the forces in component form. Identifying the perpendicular components of the forces relative to point O is crucial for determining the required force F_3. Participants suggest preparing calculations and visual aids to clarify the problem. Understanding the relationship between the forces and their points of application is essential for solving the torque equation effectively.
merced
http://img300.imageshack.us/img300/4792/physics1gj9.th.png
"Two forces F_1 and F_2 act along the two sides of an equilateral triangle as shown...Point O is the intersection of the altitudes of the triangle. Find a third force F_3 to be applied at B and along BC that will make the total torque zero about the point O."
So the sum of the torques = 0. I don't know what to do first. Should I put the forces into component form and take the tangential component of the forces??
Unfortunately, I can't see the image, but putting the forces into components would be a good start.
Click on the image.
merced said:
Click on the image.
I don't have anything to click on, it's my computer, probably. Someone else will be able to give an exact reply to you. In the meantime, prepare some work to present.
I guess what I mean is, how do I determine what is perpendicular to the intersection (O)? Because I have to use the perpendicular force right?
