Build Paper Bridge: Guidelines & Suggestions
The project requires building a free-standing paper bridge using only paper and Elmer's glue, adhering to specific dimensions and weight limits. A 5cm cube must pass freely beneath the bridge, and lamination is prohibited. Suggestions include folding or rolling the paper to increase rigidity and support weight, as folding can reinforce structures like columns and arches. Participants share their experiences and techniques, emphasizing the importance of using lightweight materials effectively. Overall, creative approaches to design and construction are encouraged to meet the project guidelines.
scoles
I just got this project for my physics class. I need to build a paper bridge out of only paper and Elmer's glue. The bridge must be free standing with the highest point on the bridge being the roadbed (i was thinking i could do a suspension bridge, but I can't under that guideline). The bridge must fit within the following dimensional ranges:
Aspect Maximum Minimum
weight 99 g none
height 20 cm 5 cm
width 10 cm 3 cm
length 60 cm 40 cm
in addition, a 5cm by 5cm by 5cm cube must be able to pass freely beneath the bridge from its lowest point up. No lamination is allowed (a build up of five or more consecutive layers of paper in difect contact or separated by only glue)
any suggestions? I'm starting on a bridge with an arch but I'm not sure what to put to support the arch...
Hi,
Did you figure out a way to this project? I have the same project now and am not sure how to start. Can you please help by giving me some pointers?
\Krishna
Can you fold the paper in anyway? Intuitively it seems that you could make the paper a little more rigid by rolling/folding the paper up. Plus it will decrease the size.
As to the arch idea -- you could, however the idea of the arch is that it supports itself
I will have to roll the paper.However, rolling the paper does not make the paper tough to hold even some ounces. I need it to take on more weight
Well a single sheet of looseleaf paper weighs only like ~0.9g so you can use a lot. I don't know how much the glue will add to the weight however, I'd bet not that much. You can't laminate but you can fold the paper as many times as possible if you wanted to. Folding the paper reinforces it (great for making columns, arches, etc.) Honestly I decided to do this and I've gotten it to work with both columns and arches^^
