Solve 0.700 Ohm Resistance Wire Length w/ 0.900 g Copper
  • Thread starter Thread starter BunDa4Th
    Stuck
To determine the length of a wire made from 0.900 g of copper with a resistance of 0.700 ohms, the relevant equations include R = pL/A, where p is the resistivity of copper. The user initially struggled to find the cross-sectional area (A) but was guided to calculate the volume of the wire using V = m/d, where the density of copper is approximately 8960 kg/m³. With the volume known, the relationship between volume, area, and length can be applied to solve for the length of the wire. Ultimately, the user successfully found the answer after clarifying the necessary calculations. Understanding the relationships between mass, density, volume, and resistance is crucial in solving this problem.
BunDa4Th
Suppose that you wish to fabricate a uniform wire out of 0.900 g of copper. If the wire is to have a resistance R = 0.700 ohm, and if all of the copper is to be used.
(a) What will be the length of the wire? M
R = pL/A
R = .700 ohm and p = 1.7 x 10^-8
first thing i did was input the given number
.700 = (1.7x10^-8)L/A
my main problem is finding A with the given weight of copper, but this is what i did.
n = m/M = .900/63.54 = .0142 then,
.0142(6.02x10^23) = 8.53 x 10^21
this is where i get lost because to get A its A = DeltaQ/DeltaT but time was never a given and i believe its not needed.
(8.53 x 10^21) x (1.6 x 10^-19) = 1364.8
I know there are other ways to get "A" by A = DeltaV/R but Volts were never given.
Any help on this would be great.
It looks like you are trying to find the number of electrons in the copper or something like that?
In your formula R = pL/A, A is the cross sectional area of the wire. It's not the current, or anything else to do with Amperes.
Start by finding the volume of the wire from the mass and the density of copper.
okay that seem to be wrong from what I thought I was suppose to do. I am suppose to find the length of the wire but I don't know how and i guess i read the wrong things.
How would i calculate the volume of the wire? I have no knowledge in chemisty so what would the density of copper be?
Okay, i think i got it
V = m/d
V = .0009/8960 = .0000001 m^3
OK, now you know the volume, you have two unknown quantities, the area and the length, and two equations:
volume = area * length
R = pL/A
Thanks for the help. I was finally able to get the answer
