What Causes Oscillation Errors in Air-Track Glider Experiments?
  • Thread starter Thread starter animanga008
    Spring
Oscillation errors in air-track glider experiments can arise from incorrect calculations related to angular displacement. The glider, attached to a spring, oscillates with a period of 1.50 seconds and a maximum speed of 46.0 cm/s, with an amplitude of 11 cm. A user attempted to calculate the glider's position at t=26.0 seconds using the formula x = A cos(wt) but received an incorrect answer. The error was identified as a misconfiguration of the calculator, which was set to degrees instead of radians. Properly using radians in calculations is crucial for accurate results in oscillation problems.
animanga008
An air-track glider is attached to a spring. The glider is pulled to the right and released from rest at t=0. It then oscillates with a period of 1.50 s and a maximum speed of 46.0 cm/s.
I found the amplitude to be 11cm (this is 100% correct)
1) What is the glider's position at t= 26.0 s?
How do i do #1?
I used the formula x = A cos ( wt) and plugged everything in.
x = (11cm) cos (26sec x 2pie/1.5)
x = -3.56
but my answer is wrong :-(
Your angle 26*2*pi/1.5 is in radians, but I think your calculator was set to work in degrees.
