Could Sirius A/B Trigger a Supernova?
  • Thread starter Thread starter Mike2
    Supernova
The Sirius A/B binary system is unlikely to trigger a supernova, as type Ia supernovae typically require a white dwarf to accrete mass from a red giant companion, which Sirius A is not. Sirius B, a white dwarf, is about 20 AU away from Sirius A, making mass transfer improbable. Some discussions suggest that an additional body could have perturbed Sirius B's orbit, potentially leading to a scenario where it falls into Sirius A. However, current models indicate that Sirius B is too distant to gain the necessary mass for a supernova event. Overall, the consensus is that the conditions for a supernova in the Sirius system are not met.
Mike2
I understand that main sequence/white-dwarf binary systems are the cause of type Ia supernovae. Is it possible that the Sirius A/B system could go supernova? The white dwarf, Sirius B, is an unusually large dwarf, about 1 solar-mass. While Sirius A is a 2.1 solar-mass main sequence star. The orbital radius is rather large, about 20au. So it seems there would be no ability of material to be sucked from A to B to make it go supernova. But some seem to think that there is another body in orbit with them that has perturbed Sirius B in the past. What would happen if this caused Sirius B to fall into Sirius A? Would there be a supernova in that case? Thanks.
Astronomy news on Phys.org
Interesting question. Here is a discussion on the subject.
What are the progenitors of the supernova type 1A explosion?
http://www.astro.rug.nl/~onderwys/ACTUEELONDERZOEK/JAAR2001/jakob/aozindex.html
Does anyone know where Sirius B is right now in relation to Sirius A? Is B at present visibly orbiting away from A? Or is it eclipsing, or headed into A? Thanks.
I'm sure someone has a model or simulation of the Sirius binary system. It certainly is getting a lot of attention. Somewhere I read a comment that the Sirius binary system is surrounded by an Oort-type cloud system, so presumably there are nearby masses which perturb the orbits of the stars.
Meanwhile -
http://mintaka.sdsu.edu/faculty/quyen/node1.html
http://www.star.le.ac.uk/wd/wd/current.shtml
Unlikely Sirius B will go SNIa. SN1a's progenitor stars are believed to be white dwarfs - which Sirius B is. The fuel source is believed to be a red giant companion star - which Sirius A is not. Albeit Sirius A will likely [not soon enough to worry about] evolve into one. The other factor is distance. It appears Sirius B is too distant from its future RG companion to accrete mass in the manner believed necessary to put on a really big show:
http://www.astronomycafe.net/qadir/ask/a11207.html
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
