Conformal Mapping of Aerofoil at incidence
The discussion centers on the conformal mapping of an aerofoil at incidence, with participants confirming that the Joukowski transformation is indeed relevant. The transformation utilizes complex numbers and is linked to conformal mapping principles. One user expresses uncertainty about their implementation, noting that their program successfully plots zero incidence but fails with added incidence, resulting in unexpected outputs. The conversation highlights the challenges of applying the Joukowski transformation in practical scenarios. Overall, the topic emphasizes the importance of understanding complex transformations in aerodynamics.
PhysicsIsFun
Does anyone know what the conformal mapping of an aerofoil at incidence is?
Does it use the Joukowski transformation? Or something else..
Thanks
I don't remember this for sure but I believe it IS the Joukowski transformation. The trans. uses complex numbers with the circle and all that and conformal relates to a complex trans. and I don't remember studying other uses for it, so I'm probably right but don't shoot me if I'm not. :wink:
Hmm thanks guys for the confirmation. I believed it to be:
w=z*exp(-i*alpha)+(exp(i*alpha)*b**2/z)
as it says but my program still doesn't work. It can plot zero incidence fine but then goes crazy and makes weird sausage things when I add incidence... oh well I'll sleep on it maybe
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
