Electric field between two wires and gauss law
The discussion focuses on calculating the electric field between two closely placed wires with equal and opposite charges. It highlights that, according to Gauss' Law, the electric field from a charged wire decays with distance and that charge distribution around the wires will not be even when they are close together. Participants suggest referring to textbooks on electrostatics, particularly those covering capacitance for parallel wire configurations. Online resources, including images and tutorials from MIT, are recommended for further understanding. The user expresses a willingness to explore these materials for better insights.
frankness
I'm not entirely sure how to word this without a diagram, but please bare with me!
In an ideal case, the charge on a wire is evenly distributed.
According to Gauss' Law, an electric field from a charged wire decays with 1/r
where r is the distance from the centre of the wire.
Say two wires, with equal and opposite charge and a large radius, R, are placed very close together.
At the closest points, the electric field will appear as if between parallel plates.
When close together, the charge distribution will not be even around the circumference of the wire. How would one go about calculating the charge distribution?
Ultimately looking towards calculating the x component of the electric field in the z direction, ie moving through the gap between the wires.
Any help on this would be much appreciated, even just to be pointed in the direction of a relevant book or website.
Cheers
Welcome to the PF, frankness. Do you have a textbook that covers electrostatics? This type of situation is usually covered in the sections that discuss how to calculate capacitance for different geometries (like a parallel-wire transmission line, which is the situation you are asking about).
To find something online for you, I did a Google Images search on electric field capacitance of parallel wire transmission line, and got some good hits. Here's the hit list:
http://images.google.com/images?svn...lel+wire+transmission+line&btnG=Search+Images
And here's a good tutorial from MIT:
http://images.google.com/imgres?img...18&gbv=2&ndsp=18&svnum=10&hl=en&safe=off&sa=N
Hope that helps. Feel free to post follow-up questions after you have gone through the materials some.
Thanks that MIT link is excellent.
I only have a basic E&M textbook and have been finding it hard to get to the library outside of my work hours.
I'll try working through it over the next few days and see how I get on.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
