Why Did My BitTorrent Download Speeds Drop After Changing My Internet Plan?
  • Thread starter Thread starter TSN79
A user experienced unexpected download speed issues after downgrading their internet plan from 6 Mbit down to 3 Mbit down, despite having sufficient bandwidth. They noted that their download speeds with BitTorrent rarely exceeded 3 Mbit, while other sources often surpassed 10 Mbit. The discussion highlights that BitTorrent requires a balance between upload and download speeds, as excessive upload bandwidth can hinder download performance. Additionally, having multiple open connections in a torrent client can consume CPU resources, leading to slower downloads, especially if running other CPU-intensive applications. For multi-core processors, increasing the priority of the BitTorrent client can help improve download speeds, although this is not advisable for single-core systems.
TSN79
I recently had 6 Mbit line (down) and 1 Mbit up. I never experienced that all of my download capacity was utilized, seldom as much as half even. So I changed my line to 3 (down) and 0.5 (up) Mbit instead. This had an unexpected effect in that my download speed was cut pretty much in half. I don't see how this should happen since my bandwidth should still be large enough to cope with the speeds to which I'm accustomed. Any ideas on why this is happening?
Computer science news on Phys.org
I have a 16 meg connection but very rarely achieve 3 meg download speeds with bit torrent but can easily exceed 10 megs when downloading from other sources.
With bit torrent i believe you have to give to receive but at the same time you have to restrict how much bandwidth you are prepared to give to those uploading from you as you require a certain amount of upload speed for yourself as data needs to be sent backwards and forwards to be checked for errors . In other words give to much and you slow down your downloads. I generally allow half of my upload speed to used for uploads to others .
obviously bit torrent should not be used to download copyrighted material
Dude, that totally worked! Thx!
No problem
Another problem with torrent downloads is that all of the open connections will eat up CPU time. If you use another program that is intensive on your CPU in addition to the torrent downloader and you end up eating all of your CPU bandwidth up, your downloads will slow. If you have a multi-core computer and are running into this problem, you can increase the priority of the bittorrent downloader to achieve faster speeds without too much interference with whatever else you want to do. (I wouldn't recommend this on a single processor computer though as it will slow your system to a crawl)
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
