Solve Circuit Questions: 5k Ohm Internal Resistance & 2000 kW Peak Power Output
  • Thread starter Thread starter CL39
    Circuit
To convert a meter with a 5k Ohm internal resistance and a full scale of 50 microA into a 1000 range voltmeter, a resistance of 19.95 mega Ohm must be added in series. For the electrical supply line loading question, when the voltage is reduced from 480V to 240V while maintaining a peak power output of 2000 kW, the supply line losses will increase by a factor of four. The discussion also touches on the importance of proper forum etiquette, questioning the placement of the topic in the correct section. Overall, the thread emphasizes the calculations needed for electrical measurements and the implications of voltage changes on power loss.
CL39
1. An electrical meter has an internal resistance of 5k Oh, and registers full scale of 50 microA. How many mega Ohm to insert in series to turn meter into a 1000 range voltmeter?
2. An electrical supply line loading question. Some large piece of electrical equipment ahs a peak power output of 2000 kW. If this is maintained, but voltage changed from 480V to 240V, by what ratio will supply line losses change
Thank you.
Are you a meter man?
As opposed to a meter maid?
Why isn't this posted in the Homework section? Does anybody ever read the rules?
