Load capability of an Al sheet serving as a ramp
  • Thread starter Thread starter miloziz
    Load Ramp
A 1/8" aluminum sheet is insufficient for constructing a ramp, as it lacks the structural integrity needed to support weight, particularly for a power scooter. City building codes must be considered when designing the ramp, emphasizing the importance of safety and compliance. Alternatives such as using pressure-treated lumber are recommended, with options for adding adhesive no-slip strips or diamond plate for durability and aesthetics. The discussion highlights the need for a practical and cost-effective solution to assist the tenant. Overall, a woodworking approach is suggested as a more viable option for creating a safe ramp.
miloziz
If I take a piece of 1/8" aluminum sheet that is 36" x 120" and bend each long side up 3" to create a ramp 120" long x 30" wide, How much weight would it support. My tenant has a power scooter and can't afford to purchase a ramp so I am looking for alternatives.
1/8" aluminum is not strong enough to be making a ramp with. Also, there are probably city building codes that will need to be met for the access ramp. It is probably best done as a woodworking project. Not sure of the best way to raise the money for it, though.
.125 Al sheet is hardly structural. You would be able to deform it with your hand, let alone a person on a scooter.
I think Berkeman is on the right track with using common decking materials.
thanks
I suggest building the ramp with pressure treated lumber and then putting 2 or 3 adhesive no-slip strips on it horizontally. Or if you want it prettier you could put diamond plate on it (the metal you commonly see on the running boards of trucks) You can buy it all at Lowe's.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
