Determine the length of l (equilibrium)
To determine the length l of the cord AC under a vertical force of 300N, the tension in cord AC (TAC) is given as 250N, with a distance of 0.2m between points A and B and an angle ABC of 45 degrees. The equations of equilibrium for horizontal and vertical forces lead to a complex equation involving trigonometric identities. Simplifying the equations by dividing through by 50 and using the relationship between sine and cosine can help in solving for the angle x. Ultimately, numerical methods or transforming one trigonometric function into another may be necessary to find the solution for x and subsequently the length l.
ND3G
A ring of negligible size is subjected to vertical force P. Determine the required length l of the cord AC such that tension acting in AC is TAC. Also, what is the force acting in cord AB?
P = 300N, d = 0.2m (distance between A & B), angle ABC = 45 degrees, TAC = 250N
The graph basically looks like a "Y" with C & B at the tops, A at the centre and P the downward force.
Fx = 0; Fab(cos45) - 250cosx = 0
Fy = 0; Fab(sin45) + 250sinx - 300 = 0
Fab = (250cosx/cos45)
(250cosx/cos45)sin45 + 250sinx - 300 = 0
This is about as far as I get before I start mucking it up. Can some one help me through the steps to solve for "x" so I can eventually find l?
okay, if you're sure that's the equation you want to solve, then you should realize it's a pretty nasty beast. You're unlikely to get an exact answer, but you can tidy it up so it looks a lot nicer.
First, try dividing through by 50.
then, think what sin 45/cos 45 is (hint - trig identities)
in the end you've still got an equation that looks like this:
a cosx +b sin x +c = 0
this is an absolute pig to solve, your only chance is to do it numerically, or "translate" one of the functions into the other - do you know how to do this?? i.e cos(a)=sin(a+x)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
