Velocity of a mass being pulled across a level surface
A man pulls a 67.0 kg crate across a level surface with a force of 172.0 N at an angle of 28.0° while overcoming a frictional force of 124.0 N. The net horizontal force is calculated to be 27.87 N, and the vertical force components are balanced, leading to a net force of 85.42 N. Using the work-energy principle, the work done on the crate over a distance of 2.70 m is determined to be 203.6 J. This work is equated to the kinetic energy, resulting in a calculated velocity of 2.47 m/s for the crate after being pulled. A free body diagram is recommended for better understanding of the forces involved.
ttk3
A man pulls a crate of mass 67.0 kg across a level floor. He pulls with a force of 172.0 N at an angle of 28.0° above the horizontal. When the crate is moving, the frictional force between the floor and the crate has a magnitude of 124.0 N.
If the crate starts from rest, how fast will it be moving after the man has pulled it a distance of 2.70 m?
W = Fsin(angle)
W = KE
KE = 1/2 m v^2
I started by finding the net force so that I could use the work equation:
Fx = 172 cos(28) - 124 = 27.87 N
Fy = 172 sin(28) (Fn and W cancel) = 80.75 N
Fnet = sqrt(Fx^2 + fy^2) = 85.42 N
Work Equation
85.42(2.70)cos(28) = 203.6 J
KE Equation
203.6 J = .5 (67 kg) v^2
v= 2.47 m/s
Careful, your frictional force acts in a opposing direction of your motion.. which is also angled.
And why does your F_n and W cancel? Weight comes straight down and your normal force is perpendicular to the surface.
Draw a free body diagram - it'll give you much better insight
