Simple battery question - which one to use?
  • Thread starter Thread starter 9988776655
    Battery
The discussion focuses on selecting a battery setup for a motor that draws 2A at 12V, with the goal of maximizing runtime. Two options are considered: a single 6V lithium-manganese battery at 1.5 Ah and four 1.5V C batteries in series to create 6V with a total capacity of 8.35 Ah. It is noted that the internal resistance of the batteries affects current delivery, and the lead-acid battery has a higher capacity than both alternatives. Suggestions include using a 6V lead-acid battery or a 12V lead-acid battery with a DC-DC converter to achieve the desired voltage. The conversation highlights the importance of understanding battery chemistry and capacity for optimal performance.
9988776655
My circuit powers a motor which draws about 2A of current out of my 12V lead acid battery.
12V is too much. So I want to change the battery setup.
I want the new battery setup to last as long as possible.
If I continuously use the motor which setup will last the longest?
1) one 6V lithium-manganese photo battery @ 1.5 Ah
or
2) four 1.5V C sized batteries each @ 8.35 Ah connected in series to make 6V
If I use setup 2, will my motor have access to more current?
I know that the motor can only draw current as fast as the chemical reaction takes place in the batteries.
Will setup 2 make my motor go faster than setup 1?
"Ah" refers to the energy content of the battery, not the batterys internal resistance, which is what you need to know to answer your question.
Quiz question. What is the general internal resistance of a LiMg battery vs (guess NiMh) C cell?
The lead acid 12-volt battery your talking about has a much greater current capacity, than either of the others you listed.
You need only 6-volts? There are plenty of 6-volt lead acid batteries available, and not much larger than 4-5 decks of playing cards.
Or you could stay with the 12V lead-acid car battery for the power source, and just use a 12V-to-6V DC-DC converter to make your output for the motor. You could build it yourself (like out of the National Instruments Simple Switcher series, using the Buck Converter configuration), or you can just buy a pre-made unit (I googled 12V to 6V converter, and got lots of hits).
BTW, this is just too funny. One of the first hits on that Google search was for a 12V to 6V converter, that "Allows a 6-volt wiper motor to work with a 12-volt electrical system."
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-5754
It's a freaking power resistor! :rolleyes: OMG! :smile:
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
