Determine the speed at which the water leaves the hole
  • Thread starter Thread starter Sunsing
    Hole Speed Water
The discussion focuses on calculating the speed at which water exits a hole in a storage tank and determining the hole's diameter. The speed of the water leaving the hole is calculated to be 17.15 m/s based on the volumetric flow rate provided. Participants suggest using the equation Q = Av to find the area of the hole, which can then be used to calculate the diameter. The conservation of energy principle and Bernoulli's equation are referenced as foundational concepts for these calculations. The conversation emphasizes the importance of understanding fluid dynamics in solving the problem effectively.
Sunsing
A large storage tank, open to the atmosphere at the top and filled with water, develops a small hole in its side at a point 15.0 m below the water level. If the rate of flow from the leak is 2.10x10-3 m3/min
(a) Determine the speed at which the water leaves the hole. =17.15m/s
(b) Determine the diameter of the hole. = ?
F=eta(Av/d)
I'm not sure what equation to use for this.
I'm just not sure how to start this.
Any suggestions?
The volumeteric flow rate is given by Q = Av.
You are given Q and you have apparently found v (the velocity), so just solve for A (the area) and then calculate the diameter.
a) Conservation of energy. The pressure energy of the water just inside the hole is equal to the kinetic energy of the water just outside the hole. See Bernoulli for terms in the equation.
b) I think it is acceptable (= a good approximation) to assume constant velocity across the whole are of the whole so stewartcs' formula applies.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
