How Do You Solve Difficult Matter and Energy Problems?
  • Thread starter Thread starter Manchuria
    Energy Matter
Manchuria
Any ideas anyone?
£10 sent via paypal to whoever gives the solution first :)
Who got the prize?
no-one - did it myself just.
Then you should give the prize to yourself and give a party to your PF friends of that money:wink:
