How to Calculate Electrical Energy Consumption for 230V / 50Hz / 1Ph Apparatus?
To calculate the energy consumption of a 230V / 50Hz / 1Ph apparatus, the amperage is essential, as voltage alone does not provide the quantity of energy used. The formula involves multiplying the amperage by the voltage, and considering the power factor and time for a complete energy calculation. Additional resources, like IEEE Xplore, can provide methods for electric power measurements, which may be helpful. Understanding the output work required can also aid in determining energy needs. Accurate calculations require all these factors to ensure proper energy consumption assessment.
gotlaub
How do I calculate the consumption of energy for an apparatus with these characteristics: 230V / 50Hz / 1Ph ?
You can't. That's just the type of electricity it requires, not the quantity. You need the amperage, which you then multiply by the voltage.
better toss in power factor as well as time as factors if you want energy consumed.
i know that i need the amperage...i thought there's another way to calculate the energy. thanks anyway ;)
What is the Ouptu work to be done? You can work backawrd from that.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
