Phase velocity/propagation velocity?
  • Thread starter Thread starter seang
    Phase Velocity
The discussion clarifies the difference between phase velocity and propagation velocity in the context of transmission lines. The user is trying to determine which type of velocity to use when solving a problem involving time delay and length. The equation lambda = vp * T is identified as relating to the velocity of propagation. Additionally, the relationship c = f * lambda is noted, typically applying to free space scenarios. Understanding these distinctions is crucial for accurately solving transmission line problems.
seang
what is the difference between the two, if any?
In particular, I'm working on this transmission line problem where I'm given the time delay and the length. I can solve to find some sort of velocity--is it the phase velocity, or propagation velocity?
I also have the equation lambda = vp * T. Again, is this phase velocity or propagation velocity?
Thanks,
Sean
Sounds like Velocity of Propagation...not sure though.
Lambda = v*T = v/f
where,
v = velocity of propagation
T = period
f = frequency
Also, remember that c = f*lambda for free space (which is normally assumed for some applications).
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
