Calculating Diffraction Angle and Grating Density for Interference Problems
  • Thread starter Thread starter mustang
    Interference
The discussion focuses on calculating the diffraction angle and grating density using the formula d(sin θ) = m(λ). For Problem 3, the angle θ for the first bright fringe is derived from the parameters of a pair of slits separated by 0.274 mm illuminated by a mercury vapor lamp with a wavelength of 545.5 nm. In Problem 25, the first-order maximum at 26.09 degrees is used to determine the number of lines per centimeter on a diffraction grating calibrated with the 546.1 nm line of mercury vapor. The calculations involve solving for θ and d, respectively, using the same foundational equation.
  • Understanding of wave optics principles
  • Familiarity with the diffraction equation d(sin θ) = m(λ)
  • Knowledge of the properties of light, specifically wavelengths of mercury vapor
  • Ability to perform trigonometric calculations, including inverse sine functions
  • Study the derivation and applications of the diffraction equation d(sin θ) = m(λ)
  • Learn how to calculate angles for multiple orders of diffraction
  • Explore methods for determining grating density from diffraction patterns
  • Investigate the properties of different light sources and their wavelengths in interference experiments
Students and educators in physics, optical engineers, and anyone involved in experimental optics or wave phenomena analysis will benefit from this discussion.
mustang
Problem 3. A pair of narrow parallel slits separated by a distance of 0.274 mm are illuminated by the green component from a mercury vapor lamp (wavelength=545.5nm).
What is the angle from the central maximum to the first bright fringe on wither side of the central maximum? Answer in degrees.
Note: If the formula is: d(sin thetha)=m(wavelength)
What do i do next??
Problem 25.
A diffraction grating is calibrated by using the 546.1 m line of mercury vapor. The first-order maximum is found at an angle of 26.09 degrees. Calculate the number of lines per centimeter on this grating. Answer in units of lines/cm.
Note: How do I start?
Problem 3:
You have the equation:
[tex]d \sin \theta = m \lambda[/tex]
You have [tex]\lambda = 545.5 nm[/tex]
You have [tex]d = 274 mm[/tex]
The only additional fact you need is that the first bright fringe occurs where m=1.
Solve for [tex]\theta[/tex].
Problem 25.
The same equation applies. Now you have to solve for d. d = the distance (center-to-center) between slits (lines). Once you know d you can find the number of lines/cm.
Regards on problem 3
So the problem is set up like this:
274(sin thetha)=1(545.5)
(sin thetha)= 545.5/274
thetha= sin-1(1.9908)
Right?
  • · Replies 34 ·
