What Does Ax = 0 with Many Solutions Imply About Ax = b?
  • Thread starter Thread starter jmcasall
    Matrices Proof
jmcasall
If A is an n x n matrix and Ax = 0 has many solutions, then
which ones are true??
A. Ax = b has either no solutions or many solutions
B. Ax = b has a unique solution for some b
C. Ax = b has many solutions for any b
D. Ax = b has no solutions for some b
or are all of the above false??
thanks
Think about what it means for Ax = 0 to have many solutions. If the 0's in the augmented matrix of linear equations were changed to some constants, would that change how A reduces?
Unfortunately, I don't know what you have to work with. If Ax= 0 has more than one solution, then the kernel of A is non-trivial and has non-zero dimension. That, in turn, means that the image of A is not all of Rn.
Note also that is Ax= b and v is in the kernel of A, A(x+ v)= Ax+ Av= b+ 0= b.
well this is what i kinda know
Ax=0
if you solve for x then x=0,
which will make A invertible
So, what does that say about Ax=B
Ax=0
If x= 0 is the only solution to Ax= 0, then A is invertible. If A has an inverse, how would you solve Ax= B?
However, that is completely irrelevant to your question since the question specifically says that A has MORE than one solution.
I can only repeat: if v is any vector such that Av= 0, and x is a solution to Ax= b, then A(x+ v)= Ax+ Av= Ax+ 0= Ax= b. If there are many solutions to Ax= 0, what does that tell you about the number of solutions to Ax=b?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
