Why some materials reflect light more than others?
  • Thread starter Thread starter Physicsissuef
    Light Materials
Materials reflect light differently due to their surface properties and structure. Smooth, flat surfaces, like mirrors, provide clear reflections by allowing light waves to bounce back uniformly. In contrast, rough or textured surfaces scatter light waves, resulting in diffused reflections. For instance, a mirror coated with a granular substance, such as peanut butter, reflects light less effectively due to its uneven surface. The fundamental principle is that while all surfaces reflect light, the degree and clarity of that reflection depend on the surface's characteristics.
Physicsissuef
why some materials reflect light more than others?
Science news on Phys.org
http://en.wikipedia.org/wiki/Reflection_(physics)"
The first part of this article is very exact in the explanation that light waves will reflect off of every surface they come in contact with; however, unless a surface is perfectly or nearly perfectly reflective, the light waves will return as simply diffused reflections of the energy.
For example, say I have a mirror that is totally flat and absolutely reflective. When I look at it, I see the reflection of whatever light waves are hitting upon it -those are the incident waves. I am seeing the resultant or reflection waves. Now, if I take the same mirror and coat it with peanut butter, I have a much less reflective surface. The light waves hitting it are still the same, however they are now being tossed and mixed about because the surface is granular and no longer flat. The energy (light) is still reflecting off of it, just not in the same clear manner that the original mirror reflected it.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
