How Much Does the Raft Rise When a 53kg Girl Dives Off?
A 53kg girl diving off a 4m² raft in freshwater raises the raft due to buoyant force. The buoyant force is calculated using the equation Fb = (density)(volume)(acceleration due to gravity), where the weight of the girl in Newtons is equal to the buoyant force. The correct approach involves solving for volume and height using the formula Volume = Area x Height. After correcting a typo in the problem, the final calculation shows that the raft rises approximately 1,325 cm. Understanding buoyant force and its relation to weight is crucial in solving such problems.
5.0stang
[SOLVED] Basic Buoyant Force HW Question
First time doing this, so bare with me:)
A 53kg girl dives off a raft 4m square floating in a freshwater lake. By how much does the raft rise?
Density of water = 1000kg/m^3
Use the equation for buoyant force. Then solve the equation for V.
Of course, volume = L x W x H.
g = 9.8 m/s^2
Fb = weight of girl in Newtons
My teacher gives us the equation for buoyant force as Fb = (density)(volume)(acc.due to gravity).
The answer is to be given in cms (centimeters).
Fb = (1000)(?)(9.8)
I am trying to get the volume, knowing that there is 4m squared. I am just missing the height.
Thanks for any ideas...
Okay, just looking over my notes one more time. My teacher said to use the weight of the girl (53kg) to equal Fb.
How do I convert 53kg to Newtons? I can use online calculators, but that is not helping me learn. It looks like it is 9.8 x 53 = 519.4 Newtons
So I should be getting Fb = (1000)(V)(9.8) or 519.4 = (1000)(V)(9.8).
I just have to solve for V it looks like.
I am trying to solve for volume. I have 4m ^2 given in the problem.
Okay, the formula to work from is:
1. Fb = (Density in kg/m^3)(Volume)(Acc. Due to Gravity)
2. 519.4 = (1000 kg/m^3)(V)(9.8 m/s^2)
3. 519.4 = 9800V
4. Volume = 18.87 (units?)
Is this correct so far?
How do I convert this to centimeters.?
3. 519.4 = 9800V
How do you get 4 from 3?
Are you able to understand the concept behind what you are doing? Refer to this similar problem in PF and see.
https://www.physicsforums.com/showthread.php?t=214070
Sorry for the late response. I figured out the problem.
The professor made a typo in our question, and she corrected it. I solved it very quickly after that.
Thanks anyways!
