Why Does the Ideal Gas Law Only Have Two Independent Variables?
ehrenfest
http://ocw.mit.edu/NR/rdonlyres/Physics/8-044Spring-2004/7A20B047-A049-44D6-96D2-75602F179856/0/notes_dfnitns.pdf
There it says tht the number of independent variables of a simple fluid is 2 (see the "Complete Specification" section). But the ideal gas law is PV=NkT which has 4 variables, so why are there not 3 independent variables for an ideal gas which is an example of a simple fluid?
There is another equation of state for ideal gases, U=Nc_vT. The constraint from this additional equation reduces the number of independent variables to two.
That equation will only work if V is constant.
No. Every student of thermo (including me) claims that at first, but no. It applies to all ideal gases under all processes.
EDIT: To give a little more explanation, c_v is a constant. U=Nc_vT is an equation of state that uses that constant; it's not a process subject to constraints. We could just as well write U=N(c_p-R)T.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
