How Do You Convert Voltage to Current in a Pressure Measurement System?
The discussion centers on converting voltage to current in a pressure measurement system, where the voltage is derived from the pressure using the function Vp = (.5)(square root of P). The current output varies from 4 to 20 mA as pressure ranges from 0 to 100 psi. Participants suggest using linear interpolation to establish a transfer function for the voltage to current conversion. The challenge lies in determining the appropriate equation after calculating voltage from pressure. Overall, the conversation emphasizes the need for a clear method to relate voltage to current based on the given parameters.
NeRdHeRd
A pressure measurement system uses a sensor that converts pressure into voltage according to the transfer function, Vp = (.5)(square root of P). This voltage is then converted into a current. As pressure varies from 0 - 100 psi, the current varies from 4 - 20 mA.
A. Find the transfer function equation for the conversion of voltage to current.
Known variables
P = 0 - 100 psi
I = 4 - 20 mA2. The attempt at a solution
I would attempt a solution if I knew where to start. The best I can do so far is use the given transfer function of Vp = (.5)(square root of P) to convert pressure into voltage. After that I'm at a loss as to where to get the equation for the conversion of voltage to current. Is there anyone out there that can point me in the right direction?
Yeah that's pretty vague; There is an infinite amount of different functions you can fit to the 2 endpoints given. You can use linear interpolation for the easiest transfer function based on your thinking of grabbing the corresponding voltages to the pressures/currents.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
