Divergent Harmonic Series, Convergent P-Series (Cauchy sequences)
PingPong
(a) Show that \sum \frac 1n is not convergent by showing that the partial sums are not a Cauchy sequence
(b) Show that \sum \frac 1{n^2} is convergent by showing that the partial sums form a Cauchy sequence
Given epsilon>0, a sequence is Cauchy if there exists an N such that |a_m-a_n|<\epsilon for every m,n>N.
For part (a), the sequence terms are a_n=1+1/2+\ldots+1/n, so assuming that m>n,
|a_m-a_n|=1/m+1/(m-1)+\ldots+1/(n+1)<\frac{m-n}{n+1}<\frac{m-n}{n}.
Now, if I take epsilon=1/2 and suppose that m>n>N implies that the distance between two elements is less than epsilon. But m=2n>n>N gives the difference to be 1, which is greater than epsilon, so the sequence is not Cauchy. I think I've gotten this half - am I correct??
For part (b), I'm not sure how to do it. The sequence terms are a_n=1+1/2^2+\ldots+1/n^2, so again assuming that m>n, we have
|a_m-a_n|=1/m^2+1/(m-1)^2+\ldots+1/(n+1)^2<\frac{m-n}{(n+1)^2}<\frac{m-n}{n^2}<\frac{m}{n^2}
I want to be able to find N such that m>n>N implies that this difference is less than epsilon, right? To do that, since I've assumed that m>n, if I can eliminate m from the expression, I'm good to go, but I can't figure out how to do it. Help!
I'm grasping at straws here, but I want to show that m/n^2<\epsilon. So I can say, since n<m, that n/n^2=1/n<m/n^2<\epsilon.
I know this probably isn't right, but if anybody could give me a hand it'd be appreciated.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
