Is It Possible for the Electric Potential to Be Zero in a Multi-Charge Field?
  • Thread starter Thread starter Sasha
    Potential
In a multi-charge electric field, the potential at a specific point can theoretically be zero, but it is typically defined in relation to a reference point, often taken as infinity. The potential difference is what can be calculated, not the absolute potential at a single point. Since potential at infinity is considered zero, all other potentials are measured against that reference. Therefore, while potential can be zero at infinity, it is not applicable within the field itself. The discussion emphasizes the importance of understanding potential difference rather than absolute potential values.
Sasha
Please! Help me! about potential
Can potential at any point of electric field produced with many charges be equal to zero?
1. Please post on this forum sensibly. People will be help you no matter how many exclamation marks you use in the title.
2. Potential cannot be calculated at a point. Only a 'potential difference' between two points can be calculated. Generally, the potential at infinity is taken to be zero and all other calculations are made respect to that. Hence, potential at a point means the 'potential difference between that point and infinity'. Under this definition, potential is zero only at infinity.
but infinity is not in the field. it is abroad
