Finding the coefficient of friction, ramps and acceleration
The discussion centers on the relationship between the coefficient of friction (μ), ramp angle (θ), and acceleration. It clarifies that μ can be expressed as tan(θ), although there is confusion about its dependence on mass and acceleration. The coefficient of friction is generally constant across a range of speeds, but discrepancies in experimental data, such as unexpected graph intercepts, suggest potential issues in measurement or analysis. The distinction between static and kinetic friction is emphasized, noting that the initial equation applies to static friction, while the scenario likely involves kinetic friction. Understanding these relationships is crucial for accurately interpreting experimental results involving a trolley on a ramp.
gRACK
mg sin θ/mg cos θ = μ (coefficient of friction)
sinθ/cosθ = tanθ
then does μ = tanθ/mg (which is what my teacher said, although I'm not sure i understand) OR is the above equation simplified so that μ = tanθ?
:rolleyes:
thanks for your help - and any other information on finding the frictional force, acceleration etc. would be good too. I read that the coefficient of friction is always a constant. but is this still true if the acceleration increases? i should make things clearer: i have some data from an experiment where a trolley is released from the top of a ramp, but the height is altered each time. (there's also a light gate involved too, but I'm not stuck on that yet - although any passing info would definitely be useful, thanks)edit: also, I plotted an acceleration v. sinθ (the angle of the ramp) graph, and expected that the gradient would be 9.81 , and that the intercept would either be 0, or below (due to frictional forces). instead, the intercept was actually a bit above 0 and the gradient wasn't 9.81 (but close). Should i bother trying to explain this..as i don't really know how to, or is just some discrepancy when i plotted the graph using excel?
The situation is complicated because there are two types of friction. Static and kinetic. From what you describe, this sounds like kinetic friction. SO your first equation won't really apply, as that is balancing the object with the force of static friction.
Coefficient of friction is approximately constant for a range of speeds. See the following page.
http://hyperphysics.phy-astr.gsu.edu/hbase/frict2.html
I take it you're measuring the acceleration of the trolley down the ramp and varying the angle. What you want to do is work out how the two are related again. Remember the coefficient of static fiction with be approximately constant as the trolley moves down the ramp.
