Div, Curl and all that jazz: Proving identities
  • Thread starter Thread starter Archduke
    Curl identities
Archduke
Prove:
\int\left(\nabla \times \vec{F}\right)\cdot d\vec{V} = \oint \left(\vec{\hat{n}} \times \vec{F} \right) dS
In the previous part of the question, we proved that:
\nabla \cdot \left( \vec{F} \times \vec{d} \right) = \vec{d} \cdot \nabla \times \vec {F}
(where d is a constant vector)
And also, it looks like we'll need to use the Divergence theorem.
OK, so, here I go!
\int\left(\nabla \times \vec{F} \right)\cdot \vec{\hat{n}}dV \\<br /> <br /> = \int \nabla \cdot \left( \vec{F} \times \vec{\hat{n}} \right) dV
By the relation above proved from the previous part of the question. Next, I used the divergence theorem:
<br /> <br /> \int \nabla \cdot \left( \vec{F} \times \vec{\hat{n}} \right) dV = \oint \left( \vec{F} \times \vec{\hat{n}} \right) \cdot d\vec{S}
My question is...Is \oint \left( \vec{F} \times \vec{\hat{n}} \right) \cdot d\vec{S} = \oint \left(\vec{\hat{n}} \times \vec{F} \right) \cdot d \vec{S}?
My initial thought is that it isn't, as the cross product isn't commutative. If that is thecase, where else have I gone wrong?
Cheers!
What is the orientation of the surface in each integral?
Erm, I'm don't know what an the orientation of a surface is, but I've had an idea.
I know that:
\vec{F} \times \vec{\hat{n}} = -\vec{\hat{n}} \times \vec{F}
and that:
\int_{a}^{b} f(x)dx = - \int_{b}^{a} f(x)dx
But, since it's a closed integral, I guess if we reverse the 'order' of integration, it doesn't matter if we do: the start and end points are the same...and the minuses cancel. Seems a bit of mathematical trickery to me, though. :frown:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
