Can the Concept of Humidity Be Applied to Non-H20 Molecules?
Relative humidity is defined as the amount of water vapor in the air compared to the maximum amount it can hold at a specific temperature, expressed as a percentage. However, this definition is specific to Earth's atmosphere, prompting a discussion on whether a more general formulation of humidity could apply to other substances. The concept of humidity is linked to the statistical distribution of molecular speeds and the vapor pressure of substances in liquid form at certain temperatures. It is suggested that humidity values could be calculated for other liquids, such as mercury, by determining saturation values experimentally, as theoretical predictions may not always be accurate. Additionally, the idea extends to calculating dew point values for various molecules, including those in different planetary atmospheres, like methane on Titan or other substances on Venus. The effective relative humidity for any molecule can be derived by dividing its partial pressure by its saturation vapor pressure, allowing for humidity calculations even in the absence of liquid.
Simfish
So we define humidity as..
"Relative humidity is defined as the amount of water vapor in a sample of air compared to the maximum amount of water vapor the air can hold at any specific temperature in a form of 0 to 100%"
But these definitions of humidity are overly specific to Earth's atmosphere. Is there a more general formulation of the concept that could apply to other molecules? I know that it's related to the statistical distribution of speeds in a group of molecules (and the respective vapor pressure of such molecules if they are found as a liquid under specified temperatures). So if there was enough mercury liquid, could we have a humidity value for mercury? (would saturation values be determined experimentally since theoretical results for all molecules can't always be precise at 2008's lvl of understanding?). And then could we also have dew point values for other molecules like mercury? (or say, methane on Titan's atmosphere, or some other molecule on that of Venus?)
Chemistry news on Phys.org
You can divide the partial pressure of any element or molecule by its saturation vapor pressure to determine its effective relative humidity.
You could calculate the "humidity" of mercury even without any liquid present.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
