Complex Variables integration formulas
MadCow999
Let C. denote the circle |z-z.|= R, taken counter clockwise. use the parametric representation z= z. + Re^(io) (-pi </= o </= pi) for C. to derive the following integration formulas:
integral C. (dz/(z-z.)) = 2ipi
note: z. and C. represent z knot and c knot , and </= represents less than or equal to
and o represents theta
i was able to do some work to it, but i eventually came out with (integral of) (R i e^io)/R which goes to integral of (i e ^(io))from -pi to pi, which comes out to e^(ipi) - e^(-ipi), which my teacher showed me comes out to zero. (i didnt quite understand his method, but i do know 0=/=2ipi
T_T
thanks!
It's a little hard to follow your notation. But for simplicity put 'z.'=0 and R=1. Then you are integrating (1/z)*dz where z=exp(i*theta). You are not integrating exp(i*theta)*d(theta) which it looks like you are doing. exp(i*pi)=(-1). exp(-i*pi)=(-1), so difference is zero. Your teacher was right about that.
hmm. so it seems to work if 'z.' = 0, but how can i say that? same goes for R = 1
is it because z. is just some arbitrary point i can pick?
we've done integral of (1/z)*dz, where z= R(exp(i*theta)) and dz = R*i(exp(i*theta))d(theta)
that comes out to be 2i*pi, but we were also doing over the interval of (0 to 2pi)
we're supposed to prove it in general i believe, so i would like to try and leave the z. and R in there.
i think I am seeing the relationship now...do i just say let z= z-z. and that yields the same (1/z) integral I've done before?
sorry bout sort of train of thought post...just trying to keep you updated with what I am doing :)
If you did it with z.=0 and R=1 I think you'll have no problems working it out in general. Yes, you'll get the same thing. You should notice the exponential part and the R just plain cancel. Welcome to PF.
okiedokie
thanks!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
