Easy question on diffraction of light
  • Thread starter Thread starter Sabrina_18
    Diffraction Light
The discussion revolves around calculating the number of observable diffraction orders for two wavelengths of light (520nm and 520.8nm) using a diffraction grating with 400 lines per mm. The calculation involves determining the grating spacing (d) and applying the diffraction equation N = dsinθ/λ. The user finds that for the first wavelength (520nm), the calculated value is approximately 4.8, suggesting that 4 orders can be seen. Another participant confirms the math is correct, reinforcing confidence in the solution. The thread concludes with a hopeful affirmation of the answer's accuracy.
Sabrina_18
[SOLVED] Easy question on diffraction of light please help!
Wavelengths are; 1 - 520nm
Wavelength 2 - 520.8nm
Diffraction grating - 400 lines per mm
How many orders will the lines be seen in?
N = dsin0/lamda
d = 1/4 X 10^5 = 25 X10^-7m
25 X 10^-7 / 520 X 10^-9 = 4.8
So is the answer 4? for the first wavelength (520nm)
Your work looks good to me.
I got 4.80769, so your math is correct.
Thanks - hope its right!
