Why Does My COMSOL Model Not Converge at Higher Heat Flux Values?
  • Thread starter Thread starter martingotu
    Comsol
COMSOL Multiphysics users often encounter convergence issues when increasing heat flux values in non-isothermal flow models. The inability to converge at higher heat flux is not fundamentally restricted but varies based on the specific problem setup. Adjusting solver settings, refining the mesh, or modifying boundary conditions can help achieve convergence. Users are encouraged to explore these adjustments and consider the physical implications of the model. Understanding the nuances of the model and solver can lead to successful solutions at higher heat flux levels.
martingotu
I need some help with COMSOL MULTIPHYSICS. I don´t have any experience with FEM analysis. I am solving a non isothermal flow model, and I am varying heat flux that enters in the subdomain through one boundary. I set a value for heat flux, solve it and increase the value to solve the model again setting the current solution as initial value. (analog to use parametric solver but doing it for myself). The question is that when the heat flux reaches a limit value the problem doesn´t converge and I need to solve the problem for a much higher value. I would like to know what is the reason for this and what can I do to get a solution.
If any of you has experience with this software I would like to ask him some doubts.
Thanks for your opinions.
Martin.
This is a duplicate post of this thread:
https://www.physicsforums.com/showthread.php?t=235253
I basically answer your question:
Mech_Engineer said:
Technically speaking, there aren't any fundamental reasons you can't raise the flux past a value before the solver doesn't converge, it's really a case-by-case thing based on the problem being solved...
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
