A question of protein subunit symmetry and normal coordinate analysis
The discussion revolves around the application of normal coordinate analysis, utilizing symmetry and group theory, to C-reactive Protein (CRP) in the context of vibrational spectroscopy techniques such as Raman, NIR, and UV/Vis. The inquiry raises questions about whether this analysis could provide insights into the forces between the protein's subunits. While normal mode analysis has been effectively used in studying metal centers in proteins and their dynamics, there is less familiarity with its application to subunit interactions within larger proteins. Previous work, including studies by biophysicist David Calloway, has explored subunit motions using scattering methods, though these analyses may involve approximations that limit detailed site-specific insights. The suggestion is made to experiment with the analysis to uncover potential findings.
evidenso
Hey
Im doing vibrational spectroscopy (Raman, nir, vis/uv) of a protein called C-reactive Protein. Its a symmetric molecule regarding the subunits http://en.wikipedia.org/wiki/C-reactive_protein
Then i wondered if one can apply normal coordinate analysis (using symmetry and group theory) to the molecule? does this make sense? will it give any information about forces between the subunits? or am I wrong? ;)
Chemistry news on Phys.org
Interesting question. Not entirely sure myself.
I know normal mode analysis has been used quite extensively in vibrational/Raman studies of metal centers in proteins, as well as in protein dynamics studies, looking within the protein and not among interacting monomers, leastways. I'm not familiar enough with the literature beyond that, although I do recall some work being done on using various scattering methods to study subunit motions within a larger protein (David Calloway, a biophysicist at NYU, was involved in this work). I dimly recall that there were some approximations made in the analysis of the scattering data, so you might not get as much detailed site-specific information as you'd like.
I would say try it and see what happens. Let us know how it works out!
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
