How to Determine the Max and Min Volume of a Box Using Lagrange Multipliers?
  • Thread starter Thread starter jaredmt
    Calc 3 Lagrange
jaredmt
i needed to find the max and min possible volume for a box with edges that = 200cm and surface area that = 1500cm^2 using Lagrange multipliers.
edges: 4x + 4y + 4z = 200cm
Area: 2xy + 2xz + 2yz = 1500 cm^2
Volume = xyz
i brought it down to this:
Vol = f
Area = G
Edges = g
^f = ^G# + ^g$
(# and & just means 'some number')
( ^ is the gradient of the function)
when i simplify everything out i get these statements:
yz = #(y + z) + $
xz = #(x + z) + $
xy = #(x + y) + $
x + y +z = 50
xy + yz + yz = 750when i try to replace values it seems to get messy. do i just throw in random values for # and $ or something? I am 99% sure that they cannot = 0. that is pretty much all i can say from these statements right now lol
Let's call L=# and M=$. Subtract your first two equation from each other. This gives (x-y)*z=L*(x-y). Or (z-L)*(x-y)=0. This tells you either z=L or x=y. Similarly y=L or x=z, or x=L or y=z. If you think about it, in any case, two of the lengths must be equal. Put this information into your last two equations. Now you have two equations in two unknowns. Not hard to solve at all.
ok cool, thanks a lot, found the answer
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
