Pressure Drop & Flow Rate for Oxygen Delivery Tube
The discussion focuses on calculating the pressure drop and flow rate for a home oxygen delivery system using a 50-foot tube with a 0.1-inch diameter. The relevant formulas for pressure drop, based on Poiseuille's law, require converting units to MKS and considering the viscosity of air. A participant raises concerns about the flow rate, suggesting that a delivery rate of 2 liters per second would result in an unreasonably high mean flow velocity of 395 m/s, which is supersonic. They propose that the intended flow rate might actually be 2 liters per minute instead. Accurate calculations depend on clarifying the flow rate to ensure proper assessments of pressure drop and flow dynamics.
wjt
I am on home oxygen and receive the gas through a 50feet long tube about .1" inside diameter.If the Machine delivers a flow rate of two liters per second, what is the pressure drop through the tubing; What is the flow rate at my end of the tubing?
If Poiseuille flow holds for your system (and it most likely does if the flow is laminar and steady), the relevant formulas are:
\Delta P = \frac{8LQ\mu}{\pi R^{4}}, where
\Delta P is the pressure drop between inlet and outlet, L the length of tube, Q the volumetric flow rate (liters/min, for example), R the tube radius, and \mu the viscosity (in Poise, or equivalent)
So, you have mixed units- convert everything into MKS. Air at room temperature has a viscosity of about 17 *10^-6 Pa*s. Now you can calculate the pressure drop.
The flow rate at the outlet is the same as the inlet- conservation of mass.
If there are viscous losses (entirely possible given the aspect ratio of tubing and flow rate), then YMMV.
You can use the Bernoulli losses formula to calculate it.
(\frac{P1}{\gamma} +Z1) -( \frac{P2}{\gamma} +Z2) = \frac{8fLQ^2}{\ g(Pi)^2D^5}
Q is the flow rate.
P is the pressure at point X.
f is the friction factor of the pipe.
L is the length of the tube.
gamma is ro*g.
Z is the elevation at point X.
Hi wjt, could you please re-check that data as it seems a bit unreasonable. Fluid at 2L/second through 0.1 inch diameter would give a required mean flow velocity of 395m/s which is supersonic.
In SI units :
Flow Rate, Q = 2E-3 m^3/s
Radius, r = .1 * 2.54E-2 / 2 = 1.27E-3 m
Cross section : A=pi r^2 = 5.07E-6 m^2
Therefore the mean velocity is, Q/A = 395 m/s
Are you sure it's not 2L/min instead of 2L/s ?
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
