Help with electromagnetism problem
  • Thread starter Thread starter Darth Geek
    Electromagnetism
The problem involves calculating the potential difference between the ends of an airplane's wings, given its wingspan, speed, and the Earth's magnetic field. The key equations for magnetic flux and induced potential difference are provided, emphasizing the need to treat the wings as a rectangular conductor moving through a magnetic field. The main challenge is determining the effective area facing the magnetic field, as only the wingspan is given. The discussion highlights confusion over interpreting the wingspan as either the width or length of the conducting element and the necessity of understanding the plane's motion through the magnetic field. Ultimately, the solution requires recognizing the relationship between the airplane's speed and the magnetic field to find the induced emf.
Darth Geek
An airplane with a wingspan W = 30 m is flying due north at v = 672 km/h. The Earth's field is 1.210-4 T, due north and inclined q = 42 below horizontal. What is the magnitude of the potential difference between the ends of the wings?
http://media.apexlearning.com/Images/200408/06/ba941605-5eb4-4e21-a8eb-b2cb82a7c95e.gif
Magnetic flux: φ = B · A · cosθ
Induced potential difference (emf)
due to a changing magnetic field: V = -N · ∆φ/∆t
Motional emf: V = -B · L · v
Could be anyone of these. Also, the problem said to treat it like pulling a rectangular wire through a magnetic field, and find the area facing the field using the angle.
It seems this is more of a riddle than a problem. How do I find the area facing the magnetic field? I'm only given the wingspan!
The wingspan gives you the length dimension of conducting rod right? So how can you get the width given the velocity of the plane?
Well, the plane is traveling into the field, so I would think the wingspan is the width. So it's the length I don't have. And it's not a conducting rod. The hint said to do the problem as if it was a rectangle circuit, and anyway I don't think there would be any potential difference if it was just a rod.
Depending on your setup and how the conducting rod is moving with respect to the magnetic field, you can interpret the wingspan as either the width or length. The term conducting rod is just to relate the situation to a very similar one which you are familiar with.
EDIT: By the way I can't access your picture. It's appears to be "forbidden access".
Bah. It's from Apex (Not) Learning. I'll mirror it on Imageshack. Here you go.
http://img401.imageshack.us/img401/892/ba9416055eb44e21a8ebb2cwy2.th.gif
Well whatever the wingspan is, I need another dimension, and Apex is being really anal about not giving me any hints. Would I just use like 1 meter or something?
[gripe] And HOW is this related to the chapter? I don't remember seeing 'riddles' in the curriculum for electromagnetism! [/gripe]
There is already another dimension. The plane is not stationary, it's moving at a constant speed. You need to find the rate at which the conducting wings pass through the magnetic field lines, which would then give rise to a potential difference.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
